Admin Utility analysis JSON file - can't find reference guide
358
11-27-2023 03:14 AM
IrisHadarStltd
New Contributor III
I've started using the Admin Utility for ArcGIS Monitor and implemented the Mission-Critical Services JSON file.
There are a few things I hvent found anywhere:
1. referance guide to layout and elements configuration.
2. What constitutes the correct combination for the ID string in the layout section of the JSON file
Does any one know where to find it ?
thank you ,
iris
AndrewSakowicz
@IrisHadarStltd , to clarify, this utility does not build a json.  It simply imports ArcGIS Monitor internal implementation of analysis configuration (jsonb configuration field in analysis table).   This analysis configuration json is internal implementation and subject to change.  Note, analysis export/import supported feature will be available in 2024.
