I would really like the possibility to update the credentials (will be mostly password) used for registering a component. Right now (2023.0) this seems not to be possible. Passwords for example for the initial portal account or PSA do change and if these are used for registering this is a big issue.
Supplying credentials in AGM 2023.0 seems only possible during initial registration of component.
In AGM 10.8.1 this was possible to update an account afterwards.
Hi @Sander,
The ability to update login credentials for a registered component is part of the ArcGIS Monitor dev roadmap and planned for a future release.
Hope this helps,
