SSL Certificate Checker
1383
06-21-2023 09:03 AM
tschultz
It would be great to be able to check the validity of an SSL certificate on an endpoint and to alert when that certificate is expiring within a certain amount of days.  This was implemented as a common extension for previous versions of ArcGIS Monitor.  Alternately, this could be an add-on to an HTTP collector, if that was made available with a new ArcGIS Monitor release.
3 Comments
EsriEvan
Hi @tschultz - Thanks for this suggestion! The dev team will be considering how to implement this as part of a future release. As you said, either as a core feature or through supporting extensions
Joshua-Young
Has the status of this changed? This was a feature in ArcGIS Monitor 10.8.1 and was very helpful to get an email alert X number of days out from a certificate expiring. It would also be great to see this in a dashboard.
AndreaRegalado1
