ArcGIS Monitor: Analysis Elements for Enterprise Geodatabases
920
12-12-2024 01:41 PM
DerekLaw
Esri Esteemed Contributor
2 4 920
This blog discusses how to configure dataview expressions and charts in ArcGIS Monitor that show enterprise geodatabase metrics. The analysis elements discussed are:
  1. Number of connections to the eGDB
  2. Connections to the eGDB over time
  3. Number of versions in the eGDB
  4. Number of version states in the eGDB
  5. Number of state lineages in the eGDB
Configuring these analysis elements for your registered enterprise geodatabases can provide insights on their activity and usage in ArcGIS Monitor.
4 Comments
ChaseBarnard
I am not seeing any of the GDB_* metrics available in Monitor (2024.1.1) instance.  I'm running the latest Monitor agent on the database machine. Does the geodatabase need to be a certain version for these to be available?
Chase
DerekLaw
Hi @ChaseBarnard,
I am not seeing this behavior. Sorry. Please open an issue with Esri Tech Support so they can help investigate further.
Not that I am aware of. Please check the ArcGIS Monitor product life cycle document to ensure your geodatabase is part of the supported ArcGIS Enterprise releases.
Hope this helps,
ZahidMia
Hi @DerekLaw
I have registered the SQL server database in ArcGIS Monitor 2023.3.1 and looked into Preparation section of the document ArcGIS Monitor: Analysis Elements for Enterprise Geodatabases.
However it is registered as TypeDatabase and Subtype: SQL Server, can't see any geodatabase subtype. Just wondering how can I separate them as database and geodatabase. Is there any separate workflow to register the database as Geodatabase, please.
Please note the SQL Server database is in Azure SQL Server.
DerekLaw
Hi @ZahidMia,
However it is registered as Type: Database and Subtype: SQL Server, can't see any geodatabase subtype.
Are you sure the SQL Server database you registered with ArcGIS Monitor is an enterprise geodatabase? This indicates that Monitor is not seeing the geodatabase repository tables that should be in the SQL Server database.
No, registering a database or enterprise geodatabase with Monitor is the same. And Monitor will detect which type it is.
Please contact Esri Tech Support and ask them to help you investigate further if you're certain the SQL Server database is an enterprise geodatabase.
Hope this helps,
Contributors
About the Author
Senior Product Manager - Twitter/X | Mastodon | Bluesky : @GIS_Bandit
