how can I connect maritime service(SOE) in arcgis pro
925
08-17-2023 01:08 AM
songqin
I have installed ArcGIS Server(10.9.1) and the Maritime Server Object Extension (SOE), registered it with the "sampleWorldCity" service. I have also copied some .000 files into the corresponding directory (datasets). However, when I try to connect to this service from ArcGIS Pro(3.1.2), it reports a data source error. Where should I look for the issues?
this is soe servicethis is soe servicethis is rest url and dirthis is rest url and dirthis is maritimechartservice rest urlthis is maritimechartservice rest urlthis is data in sencsthis is data in sencsthis is add data from path in Prothis is add data from path in Prothis is error photo. why?this is error photo. why?
TomDePuyt
Hi Songqin,  I sent you a direct message on this.  Please see that message and contact me directly to discuss if this is still an issue.   Any resolution will be posted here for the general community.
