Hi Technical Support Team,
I have some issues when working with ArcGIS for Maritime in ArcMap as attached pictures.
1. I have problem with NIS scale band although I already configure as the picture 1, and picture 2
2. I try to create New Nautical product but the tools are not active as picture 3.
Please help me.
Thank you so much
Solved! Go to Solution.
Hi
We had the exact same problem in ArcGIS 10.8 but everything was working in 10.7! Unfortunately we didn't find any solution.
I found that should work with Enterprise Geodatabase in Arcmap 10.7
Hi
Hi
Thank you so much for support. I already installed version ArcMap 10.7 and I can work with the NIS Scale band.
However, I still have problem with New Nautical Product wizard. The tools in this wizard are not available active , although I already set Nautical properties as the attached pictures.
Please help me!
Many thanks
... have you set the NIS Owner Workspace ?
