Hi everyone,
Could anyone explain on higher level how to import all available raster datasets to sort of BIS db and generate compiled mosaic surface with ascending Survey Date order? I remember full workflow on older version of the ArcMap when I had dedicated GDB for BIS on SQL server.It was fairly straight forward process of adding all source rasters into BIS with proper metadata and then continue with extraction of soundings and reducing density and etc.
But nowadays after migration to ArcGIS Pro in 2023 I can't remember what is the alternative workflow for the mosaic surface generation part.
I would highly appreciate your ideas and suggestions on how to complete this task in ArcGIS Pro.
Thank you in advance!
With respect,
Naur
