Trying to import a local scene into Unreal
772
02-27-2023 01:43 PM
Rumrunner
The problem I'm running into is that I'm having difficulties importing a local scene from ArcGIS Pro into the Unreal Engine.  I'm currently working on a project that involves Venus and ideally would like to create something that allows me to walk around the surface of Venus in the Unreal Engine.  I was able to use the map file that I have (tiff) with the DEM (also in tiff format) to create a local scene in arcgis, but I'm unsure of how to get this over to the engine.
I have searched through the tutorials and it seems pretty straight forward if everything is on Earth and there's a basemap available, but things get not so easy otherwise.  I was wondering if anyone has an idea of how to go about this or could direct me to a tutorial that would help.
Sorry for the vagueness of this post.
Jade
by Esri Contributor
Hello, if you're still working on this project, you should convert your data to the data type we support listed on this page https://developers.arcgis.com/unreal-engine/layers/
