Sync the edits of a 3Dobject Scene Layer
819
11-26-2025 05:04 AM
jornkri
Just a quick question:
If you add a 3D object Scene Layer in Unreal through the ArcGIS plugin, will edits to this layer be updated in Unreal?
For example: If you move (x,y and z) a building (3D object Layer) in a web scene, and the same building has been added to Unreal via the plugin, will I see changes made to the building also in Unreal?
AShahbaz
I have not tried this but I believe that would not happen in real time. The meshes that are loaded with the outdated data would not refresh automatically. You probably would need to force a reload to see the changes (e.g., reopening the level or refreshing/recreating the map)
