Unity 6 Memory leak
4112
10
03-25-2025 05:22 AM
ChristofferLindellBolin
After upgrading from Unity 2023.1 to Unity 6 I am having a really bad memory leak from ArcGIS and I can't figure out as to why. It is related to the ArcGIS SDK since when disabling it I have great performance.
I have attached a memory snapshot where I compared the memory usage after running 1 hour just rendering the ArcGIS map and it is quite noticeable that an additional 13+ million new objects for ArcGISRuntimeEnvironmentErrorEventInternal is created during this time and this is the cause of the leak. I have no issues rendering the map at all and I receive no other errors.
I do however receive the following warnings:
System specs:
ArcGIS Unity SDK 1.7 (have also tried to downgrade to 1.6 that we use in 2023.1 and the memory leak is still present)
2 Solutions
MichaelBranscomb
Esri Frequent Contributor
@YifengChen In our next release in August we plan to include a fix for the memory leak reported by the users on this thread. This specifically addresses the issue of excess ArcGISRuntimeEnvironmentErrorEventInternal objects created.
If you're seeing the same thing in your memory snapshots, I can share details of the fix which comprises changes you can apply yourself and test now (but note you cannot use in production until you update to the official release in August). Please contact me at MBranscomb@esri.com and we can arrange to include you in the programme for testing this fix.
Thanks
Mike
MichaelBranscomb
ArcGIS Maps SDK 2.1 for Unity was released last week and includes the fix for the memory leak discussed in this thread.
ArcGIS Maps SDK for Unity | Integration | Unity Asset Store
Release notes | ArcGIS Maps SDK for Unity | Esri Developer
Thanks
I have now updated to 2.0.0 and the issue still persists. I would appreciate if anyone at Esri could take a look into this since this is an urgent need of ours.
FabioPizzella
I'm having the exact same issue and for this reason the app (both macOS and Windows builds) is crashing after a few hours of use (out of RAM). The value you see in the screenshot goes up really fast, allocating a lot of GB over time.
Using Unity 2022.3.62f1 LTS and ArcGIS 2.0.0.
I have been in contact with Esri and have received a hotfix from them. This should be fixed in their next release 2.1 during July/August. However, I don't think I am allowed to share the hotfix with you unfortunately unless ESRI gives approval for me to share it.
FabioPizzella
@ChristofferLindellBolin thanks a lot for the update! I'll contact them myself about the hotfix.
MichaelBranscomb
Hi @FabioPizzella
Unfortunately, there is no hotfix for the issue reported by @ChristofferLindellBolin - they are currently testing a candidate fix only, under the terms of the Esri Early Adopter Programme. Please contact me at MBranscomb@esri.com and we can arrange to include you in the programme for testing this fix.
Thanks
Mike
YifengChen
I find out that is the issue of ArcGisLocationComponent, i disable all them in my scene and the memory not going up anymore, however, i dont think there will any fix soon, i ended up using other map package
MichaelBranscomb
Thanks
Mike
MichaelBranscomb
Thanks
YifengChen
I have test the 2.1, i am still getting this memory leaking issue, and 2.1 no longer support built-in pipeline?
