Problem with adding vector tile layer
1131
01-28-2023 07:25 PM
JIEWEI
Hi, I'm currently using the latest SDK for the Unity(version 1.1), while it seems impoissble to add vector tile layer to my map. I've tried three different types, but they didn't  work out.
The first one is adding a small local vptk file(aoubt 20Mb )  which works well on the arcgis pro but I couldn't see anything on unity map (I even tried discheck elevation).
The second is adding a larger local file (about 160Mb) , at that time , the Unity just stuck at the first moment , it just kept the reload script assemblies window which could be busy for over 1hour.
The last way is that I tried the url link to add the vector tile layer , it act the same as the frist way.
I just wonder how to fix this issue.
Thanks in advance.
JIEWEI
Problem solved. Well ,I change projection from WGS84 to Web Mercator  and now it works properly.😂
