Display map at certain position ? Vector support ?
941
10-30-2022 09:24 AM
LarsMatthäus
I dont really need the High-Precision Framework since i only need a flat 2D arcgis map being displayed at a certain old unity position ( 0,0,0 ).
However since the HP framework is being used, i cant really get that working... Furthermore i have the feeling that vector maps arent supported since the map is pretty low resolution.
How do i display the map ALWAYS at unitys 0,0,0 coordinates ? And how can i increase the maps resolution ?
Matt_Nelson
Esri Alum
We need the High Precision framework for our plugin to function. Can you explain a bit more about what you are trying to do.
Matt_Nelson
Esri Alum
You can define the maps origin position to be at whatever you want 0,0,0 to be
