Changing the extent in Arcgis tabletop XR
554
06-28-2024 03:03 AM
Fer
We are implementing an application based on the tablet top xr sample: arcgis-maps-sdk-unity-samples
For our use case, would be great to be able to change the extent of the map at runtime (e.g. having a bigger table to render a bigger area of the map keeping the same tiles). In a basic scene with local map type, I can easily achieve this changing the radius value in ArcGISMap component, but in the table top xr sample it doesn't work. Any suggestion on how to achieve this?
Many thanks!
