Built-in render pipeline and ArcGIS Maps SDK for Unity
596
08-18-2022 08:29 AM
WinfriedSchwan
Hi all,
I'm well aware that the SDK documentation points out that only URP and HDRP are supported and there is no support for the built-in RP.
But I'm wondering if it's worth a try to get the SDK working with the built-in RP.
The reason for using built-in RP is that I have one of the early Looking Glass holographic displays that can only be targeted with the built-in RP.
Maybe there is some workaround and maybe built-in RP can be used with the ESRI SDK with some restrictions.
Thanks for sharing any experiences with this...
Best regards
Winfried
Matt_Nelson
Esri Alum
Have you tried it yet? I do know some stuff works with the built-in render pipeline.
I know the extent cutout won't work but maybe you won't need it
WinfriedSchwan
Hi Matt,
thanks for answering... not yet but I will give it a try with the built-in RP in the next days... if the extent cutout would be the only restriction that would be perfectly fine... I will share my experience after testing...
Best regards
Winfried
