api-key doesn't work
917
04-24-2023 09:31 AM
文言李
the api-key used to work in the past 2 weeks, but from today, it doesn't work. I registerred other 2 keys, at beginning the 2nd key work for a while, but then doesn't either, 3rd key doesn't work from beginning.
any clue?
best regards
jeff
and1
by Esri Contributor
I would double-check on the location service scopes and make sure you have the respective services you'll need. In case if you need to add more services, you can click "Edit API Key" -> "Set Service Scopes" on your API settings page.
