Export to aix crashing with greater frequency at ArcGisPro 3.5.4
883
10-21-2025 06:06 AM
HylonPlumb
Since I've upgraded to the patch of Arcgispro 3.5.4, I am experiencing crashes when exporting to aix whereas before never. An .aix file is created after about 5 mins of processing, the .aix file is created and only amounts to 4kb's and the program crashes and pop-up appears where I can notify esri and provide details. I provided info many times.
What I've tried:
Clear display cached, after completing content and layers changes in layout (for example, adding layers to Legend in layout) I save project and close layout and re-open it, removing layers in the cloud and making them local when possible, changed dpi setting in export window, close map and layout and reopen just before export. I have gone through the arduous task of turning off/on layers and I found one layer was problematic which I replaced. I thought success, but the crashes continue.
Our organization uses onedrive to sync with content which is in the cloud and I understand this can be an issue. For a while, I theorized a feature layer maybe locked which caused the issue, but I am watching and exporting when all is sync'd.
Any help would be appreciated, again this is a new behavior, I've never experienced this crashing before 3.5.4.
Thanks for any thoughts,
Hylon
AnnaHartig
Hi @HylonPlumb,
I have a couple follow up questions for you. Are you able to share some more information about your current OS version? Is this only happening when exporting .aix? Or do you also see a crash when exporting other file formats? Additionally, are you able to share your Pro package with us so that we can try to reproduce this issue in house?
HylonPlumb
Hello @AnnaHartig,
Thank you for the reply.
I am running MS Windows 11 Business 10.0.262. Build 26200.
I have good results, since I upgraded to 3.6, I have not been able to replicate the issue. I was working on a batch of maps which concluded in November, but I did revisit to see if I could replicate the error which I could not. I regularly export to .aix and the style of map (which two beefier image service layers) crashed whereas working with smaller simpler maps crashes never occur.
Again, thank you for the reply and apologies I didn't see your msg sooner.
Best,
Hylon
