Product Library-Set CDR Owner Workspace
2510
12-15-2011 01:10 AM
Hsing-JuChang
I'm new to the Product Library. I'm trying to setup the NIS datatbase following these links.
Setting up the Nautical product library
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Setting_up_the_Nautical_product_librar...
Setting up the NIS database
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Setting_up_the_NIS_database/0106000001...
Everything works fine until Defining the Central Database Repository Workspace - Step 11. After clicking the ... button for Set CDR Owner Workspace, a message box says that "FrameworkEngine.CKBFile.Input Name string has exceeded the length limit of the field"(attached jpg). Does anybody encounter this problem? What does the Set CDR Owner Workspace actually do?
Thanks in advanced.
Amy Chang
NancyEl-Zeaiter
Thanks in advanced.
Amy Chang
Amy,
There is a character limit of 32, can you please verify that the name of the selected workspace does not exceed this limit?
Hsing-JuChang
Hi Nancy,
Thanks for your reply!
I built my NIS database in SQLServer Express. The property of the Central Database Repository Workspace was set using the Database Server Connection. The property of the workspace was "C:\Users\amypc\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\AMY-PC_SQLEXPRESS.gds\NIS"
I have changed the workspace property to Spatial Database Connection. The property of the workspace now is "C:\Users\amypc\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\Connection to amy-pc.sde". With is property, I'm successfully set the CDR Owner Workspace.
I'm curious about these settings.
1. Does NIS database support only Spatial Database Connection?
2. Under Nautical Properties, I have set the Central Database Repository Workspace. What's the purpose of Set CDR Owner Workspace?
Amy
NancyEl-Zeaiter
The CDR Owner connection property is to give non-admin SDE connections the ability to create products using the Enterprise workflow. This property is to be set by someone who has the SDE admin connection. Once they set this property the admin connection properties are stored in the CKB_File table and are referenced by Populate when creating replicas by non-admin users.
With SQL Express, everyone is automatically the Admin or Data owner so there is no need to set the property.
RuelMacayan1
I also have error in CDR Workspace "Unable to get CDR workspace from PLTS Info Database"
[ATTACH=CONFIG]25572[/ATTACH]
how to solve this error? What should I do?
Thanks in advance
AndyOmmen
Hi Ruel,
It looks like you need to set the NIS workspace within the Nautical Properties before running the Populate process. To do this:
1. In ArcMap, go to Customize > Production Properties
2. Click on the Nautical Properties item
3. Under the Central Database Repository section, click in the "Click to edit property" and click on the ellipses button
4. In the browse dialog, navigate to the location of your NIS workspace, select it and click Open
5. Click OK to save your property settings and close the dialog
If you don't have an NIS workspace go to the Help and search on the topic "Setting up the NIS database". Follow the steps outlined in this topic. Hope this helps.
Andy
