I am working with a "map book" that has a large number of call outs (~3000). We have a request to change the line color and weight for the leaders. The annotation is in a SDE feature class. Is it possible to do this change in bulk?
ArcGIS 10.1
Thanks!
Just to check... this doesn't do it in bulk I suppose
You certainly should be able to do this with ArcObjects. I did something kinda similar about 10 years ago using ArcObjects and VBA. I developed some internal tools to help automate and speed up mapping emergency road closures & one map product used balloon callouts that were symbolized either green (re-opened) or red (closed). Rather than drill down 12 levels in the symbol properties, I used VBA ArcObjects to quickly "flip" the color for the selected callout.
Screenshot:
And here's the VBA code:
Private Sub ToggleLabelColor_Click() '========================================================================== 'This subroutine adds a one point white halo to the currently selected label '========================================================================== Dim pIMxDoc As IMxDocument Dim pMap As IMap Dim pActiveView As IActiveView Dim pGraphSel As IGraphicsContainerSelect Dim numSel As Integer Dim pEnv As IEnvelope Dim pDisplay As IDisplay Dim pContainer As IGraphicsContainer Dim pSymbol As ITextSymbol Dim myColor As IRgbColor Dim whiteFill As IRgbColor Dim pTextElement As ITextElement Dim pCallout As IBalloonCallout Dim pFillSymbol As IFillSymbol Dim pLineSymbol As ILineSymbol Dim pTextBackground As ITextBackground Dim pTextSymbol As IFormattedTextSymbolSet pIMxDoc = ThisDocument Set pActiveView = pIMxDoc.FocusMap Set pDisplay = pActiveView.ScreenDisplay Set pMap = pIMxDoc.FocusMap Set pContainer = pIMxDoc.FocusMap Set pGraphSel = pContainer '-------------------------------------------------------------------------- 'Make sure only one label is selected. Adjust as desired.. '-------------------------------------------------------------------------- numSel = pGraphSel.ElementSelectionCount Dim index As Integer Dim pElement As IElement Dim haloSize As Double For index = 0 To numSel - 1 Set pElement = pGraphSel.SelectedElement(index) If TypeOf pElement Is ITextElement Then Set pTextElement = pGraphSel.SelectedElement(index) Set pSymbol = pTextElement.Symbol Set myColor = pSymbol.Color If myColor.Red = 255 Then 'Road is changing from closed to OPEN myColor.Red = 38 myColor.Green = 115 myColor.Blue = 0 'MsgBox "This road is closed!", vbInformation, "Results" Else 'Road is changing from open to CLOSED myColor.Red = 255 myColor.Green = 0 myColor.Blue = 0 'MsgBox "This road is open!", vbInformation, "Results" End If pSymbol.Color = myColor Set whiteFill = New RgbColor whiteFill.Red = 255 whiteFill.Green = 255 whiteFill.Blue = 255 Set pLineSymbol = New SimpleLineSymbol Set pFillSymbol = New SimpleFillSymbol pLineSymbol.Color = myColor pLineSymbol.Width = 1 pFillSymbol.Color = whiteFill pFillSymbol.Outline = pLineSymbol pTextElement.Symbol = pSymbol Set pElement = pTextElement Set pTextSymbol = pTextElement.Symbol Set pTextBackground = pTextSymbol.Background Set pCallout = pTextBackground Set pCallout.Symbol = pFillSymbol '.Outline.Color = myColor Set pTextSymbol.Background = pCallout pTextElement.Symbol = pTextSymbol Set pElement = pTextElement End If Next indexpActiveView.PartialRefresh esriViewGraphics, Nothing, Nothing '---------------------------------------------------------------------- 'Release any memory allocated '---------------------------------------------------------------------- Set pElement = Nothing Set pTextElement = NothingEnd SubPrivate Function ToggleLabelColor_Message() As String ToggleLabelColor_Message = "Toggles the Road Closure Balloon Callout Color Between Red (Closed) and Green (open)"End FunctionPrivate Function ToggleLabelColor_ToolTip() As String ToggleLabelColor_ToolTip = "Toggle Closure Callout Color"End Function
In the example above, I'm working with graphic labels within an MXD but I think the principle is the same in terms of accessing the symbol properties for a callout.
Sorry I don't have a Dot Net version of this code since we moved away from producing the PDF map based updates during events.
Steve
Ya, looks like that has to do with setting up a "default" anno style before you place it.
I have also tried selecting a bunch of them (30 or so) and updating them with the Attribute panel; however, only one is updated. Furthermore, the far end of the leader is "reset" (i.e. the length of the leader is reduced to zero). So one must drag the leader back to the feature that the anno is referring to. I fear that even if I do find a way to mass update the annotation I would still need to drag all the leaders back by hand....
Hah. Spoke too soon. Looks like I kind of have a Dot Net version of the VBA code. I frankly don't know if this works. I think it does but it's been years since I used it. Looks like this updated code only changes the color TO green in this example but you get the idea:
Imports ESRI.ArcGIS.ArcMapUIImports ESRI.ArcGIS.CartoImports ESRI.ArcGIS.DisplayPublic Class cmdMakeLabelGreen Inherits ESRI.ArcGIS.Desktop.AddIns.ButtonPublic Sub New()End SubProtected Overrides Sub OnClick() Dim application As ESRI.ArcGIS.Framework.IApplication = Nothing Dim pIMxDoc As IMxDocument Dim pMap As IMap Dim pActiveView As IActiveView Dim pGraphSel As IGraphicsContainerSelect Dim numSel As Integer Dim pDisplay As IDisplay Dim pContainer As IGraphicsContainer Dim pSymbol As ITextSymbol Dim myColor As IRgbColor Dim whiteFill As IRgbColor Dim pTextElement As ITextElementDim pCallout As IBalloonCallout Dim pFillSymbol As IFillSymbol Dim pLineSymbol As ILineSymbol Dim pTextBackground As ITextBackground Dim pTextSymbol As IFormattedTextSymbolTry application = My.ArcMap.Application Dim document As ESRI.ArcGIS.Framework.IDocument = application.Document 'pMxDoc = application.Document pIMxDoc = CType(document, ESRI.ArcGIS.ArcMapUI.IMxDocument) pActiveView = pIMxDoc.FocusMap pDisplay = pActiveView.ScreenDisplay pMap = pIMxDoc.FocusMappContainer = pIMxDoc.FocusMap pGraphSel = pContainer '-------------------------------------------------------------------------- 'Make sure only one label is selected. Adjust as desired.. '-------------------------------------------------------------------------- numSel = pGraphSel.ElementSelectionCountSelect Case numSel Case 0 MsgBox("You must select a label!", vbExclamation, "Error Encountered") Exit Sub Case 1 'Do Nothing Case Else MsgBox("You must have one label selected!", vbExclamation, "Error Encountered") Exit Sub End SelectDim index As Integer Dim pElement As IElementFor index = 0 To numSel - 1 pElement = pGraphSel.SelectedElement(index) If TypeOf pElement Is ITextElement Then pTextElement = pGraphSel.SelectedElement(index) pSymbol = pTextElement.SymbolmyColor = pSymbol.Color'Road is changing from closed to OPEN myColor.Red = 38 myColor.Green = 115 myColor.Blue = 0 pSymbol.Color = myColorwhiteFill = New RgbColor whiteFill.Red = 255 whiteFill.Green = 255 whiteFill.Blue = 255pLineSymbol = New SimpleLineSymbol pFillSymbol = New SimpleFillSymbol pLineSymbol.Color = myColor pLineSymbol.Width = 1pFillSymbol.Color = whiteFill pFillSymbol.Outline = pLineSymbolpTextElement.Symbol = pSymbolpElement = pTextElementpTextSymbol = pTextElement.Symbol pTextBackground = pTextSymbol.Background pCallout = pTextBackgroundpCallout.Symbol = pFillSymbol '.Outline.Color = myColorpTextSymbol.Background = pCallout pTextElement.Symbol = pTextSymbolpElement = pTextElement pContainer.UpdateElement(pElement) End If Next indexpActiveView.PartialRefresh(ESRI.ArcGIS.Carto.esriViewDrawPhase.esriViewGeography, Nothing, Nothing)'---------------------------------------------------------------------- 'Release any memory allocated '---------------------------------------------------------------------- pElement = Nothing pTextElement = Nothing pLineSymbol = Nothing pFillSymbol = Nothing pTextSymbol = Nothing pActiveView = Nothing whiteFill = Nothing pSymbol = Nothing myColor = Nothing pGraphSel = Nothing pContainer = Nothing pMap = Nothing pDisplay = Nothing pIMxDoc = Nothing pTextBackground = Nothing Catch ex As Exception globalErrorHandler(ex) End Try End SubProtected Overrides Sub OnUpdate()End SubEnd Class
Public Sub New()
End Sub
End SubEnd Class
This worked well in a test run:
http://www.cartotalk.com/index.php?showtopic=5401
