How To Have an .mxd File Display as an ArcGIS Online Map
3548
12-20-2015 01:58 PM
WilliamCole
I have a single use ArcGIS Pro license.  I have an .mxd file that I would like to be able to display as an ArcGIS Online Map.  The .mxd file has a number of Group Layers and each group is associated with a number of feature classes.  Is this possible in my licensed environment?  If so, please let me know what instructions I need be familiar with.
Thanks much.
Bill Cole
Fredericksburg, VA
Tags (1)
VyacheslavTomilin1
Share as .mpk package, not?
JacobTodd1
Hi William,
One thing you could try is to use the share > web map option from within ArcGIS Pro. Please keep in mind that the layers from within your map document will be published as a feature layer and a web map containing your data will be created as well.
Share a web map—ArcGIS Pro | ArcGIS for Desktop
