Hole in my Mosaic Dataset.
1963
7
07-07-2017 11:20 AM
MichaelHaley
I just created a new mosaic dataset with ArcMap 10.2.2. Added the rasters - Mr. Sid. Built the Overviews. But a hole appears in one area. Any ideas on how to fix it?
JakeSkinner
Esri Esteemed Contributor
Hi Michael,
If you keep zooming into the area with No Data are you able to see the pixels eventually?  This would indicate an issue with the overviews.  Can you provide a screen shot of what you are seeing?
MichaelHaley
Yes when I zoom in I can see the images. I it definitely a problem with the overviews.
MichaelHaley
Mosaic with hole in overviews
JayJohnson
Did you find a solution to this?  I have the same issue.
Holes in Mosaic Dataset Overviews
MichaelHaley
No I never did. Fortunately it was not in a critical area.
JayJohnson
Thanks.  I guess that is how I'm going to leave it as well.
MichaelHaley
And the odd thing is… I have multiple years of mosaics and I had the hole appearing in exactly the same spot on multiple years. Then the last time I redid our most current year, 2016, the hole did not appear where it had before. I have no idea why.
