When will ESRI release their proprietary 2022 USA demographics projections?
I assume this will not be the US Census data, which will be in a separate release and series?
Usually ESRI releases sometime around UC...is that still the case?
In the late June online release, we will be releasing Esri’s annual 2022 Updated Demographics for the U.S. It will be based on Census 2020 geography. Learn more: https://www.esri.com/arcgis-blog/products/esri-demographics/analytics/understanding-change-between-d...
You can access the Census 2020 data and geography now through Living Atlas maps, Business Analyst, Community Analyst, and Enrich Layer in ArcGIS Online and ArcGIS Pro. Learn more: https://www.esri.com/arcgis-blog/products/esri-demographics/announcements/access-2020-us-census-data...
