OpenStreetMap WGS 84 for Offline applications (download map)
2452
5
08-11-2021 04:54 AM
OlgaKoblet
Hi all,
OpenStreetMap in Web Mercator is available for offline use and can be downloaded via "Download map" in ArcGIS Pro or "Manage Areas" in ArcGIS Online. However, for the OpenStreetMap in WGS84 both options are not available. Does anybody know why? And is there a workaround?
@Andy-Green
Tags (3)
Andy-Green
Thanks for your question @OlgaKoblet .  Currently, neither our OpenStreetMap WGS84 or our Esri Vector Basemap WGS84 items are set to allow offline use.  We will re-evaluate this setting and provide an update if this changes.
Andy-Green
OlgaKoblet
Thanks a lot, that would be great!
Andy-Green
We are planning to enable export of tiles on both the Esri Vector Basemap and OpenStreetMap (OSM) WGS84/GCS versions with upcoming releases in the Q3-2021 time frame.  I'll circle back to this item when they're both fully released.
OlgaKoblet
This is great news!
Andy-Green
Esri Vector Basemaps WGS84/GCS version is available for exporting tiles (effective Sept. 2, 2021).
OpenStreetMap WGS84/GCS version is available for export capabilities as of October 28, 2021.
(Post updated to confirm both Esri and OSM WGS84/GCS versions of vector basemaps have export capabilities).
FYI:  @OlgaKoblet
