Dataset of Space Debris reentrance help
798
03-30-2022 08:15 AM
FC43253
Hi, i am a student for a Master Degree in Geospatial Engineering, and i 'm looking for extract the most mount of data that i can get from space debris reentrances on earth. I saw that ESRI has a portal view wich gives you the Satelittes in orbit. I was looking to have a temporal dataset of that list, to compare the amount of data between the years and extract the ones who disappeared.
If anyone knows where i can have it and can share the dataset, i would apreciate it.
RalucaNicola1
Hi, is this the satellite map you are referring to? The data in this app comes from SpaceTrack. You need to make an account to be able to access the data.
