Map in a minute: Map Coastal Property Loss using ArcGIS Online and ArcGIS Living Atlas
349
08-14-2024 10:33 AM
BernSzukalski
Esri Frequent Contributor
1 0 349
While coastal communities make up only 10% of the U.S. land mass, nearly 40% of the population can be found in coastal communities. An estimated $1 trillion worth of property is located within 700 feet of the coast and by 2050, it is estimated that up to $106 billion worth of coastal property will likely be impacted if current trends continue.
Using Living Atlas apps such as World Imagery Wayback, Regrid parcel boundaries, and ArcGIS Instant Apps, you can quickly and effectively view coastal change and property loss over time.
mimce-33
 For more information, see Map in a minute: Map coastal property loss using ArcGIS Online and ArcGIS Living Atlas by @BernSzukalski. The blog article covers using Wayback, using Map Viewer to add Regrid parcels, and leverages the Media Map Instant App to use its swipe tool.
Visit the ArcGIS Living Atlas home page to learn about what's new and how to use content. See the ArcGIS Living Atlas blog for more blog articles that help you get the most out of Living Atlas.
Contributors
About the Author
Esri technical evangelist and product advocate. On a good day I'm making a map. On a great day I'm on one. https://www.linkedin.com/in/bernszukalski/ bszukalski@esri.com
