Is there a way to use the .goTo() method on an array of Graphics Layers so that I can zoom to the extent of the 'broadest' (most spread out) group of graphics? I'm creating an application where users are able to select from a list of park amenities. For each amenity that they select, a new Graphics Layer is created. I then add that Graphics Layer to an array of Graphics Layers. The problem arises when there are multiple layers in the array and I try to zoom to the extent of the amenities that are toggled on.
I've tried to simply add all of the Graphics from all of the Graphics Layers to a new Graphic Layer. However, when I do this, the Graphics are removed from the Graphic Layer from which they were copied. In other words, if I have a Graphic Layer for parks where basketball courts are located, when I try to "copy" these graphics into a separate Graphic Layer, they're removed from the initial basketball courts Graphic Layer.
Since I suspect that there is no way to run the .goTo() method on an array of Graphics Layers, I believe that the workaround is to add all of my Graphics to a new Graphic Layer, but this, surprisingly, doesn't seem to work. I've spent much more time on this issue than I thought I would; any help would be greatly appreciated!
