Zoom to Button in each row of FeaureTable widget of arcgis api for js 4.x
1360
08-08-2022 01:05 AM
ImtiyazPasha
How to add image in featuretable grid in ArcGIS API for js 4. x FeaturerTable widget as suggested in below post, please suggest.
https://community.esri.com/t5/arcgis-api-for-javascript-questions/add-image-in-featuretable-grid/td-....
Below is the code for 3x
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title>FeatureTable Formatting</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.41/esri/css/esri.css">
  <script src="https://js.arcgis.com/3.41/"></script>
  <style>
    html, body, #map {
      width: 100%;
      height: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    require([
      "esri/layers/FeatureLayer",
      "esri/dijit/FeatureTable",
      "esri/geometry/Extent",
      "esri/symbols/SimpleMarkerSymbol",
      "esri/symbols/SimpleLineSymbol",
      "esri/Color",
      "esri/map",
      "esri/graphicsUtils",
      "esri/tasks/query",
      "dojo/dom-construct",
      "dojo/dom",
      "dojo/number",
      "dojo/parser",
      "dojo/ready",
      "dojo/on",
      "dojo/_base/lang",
      "dijit/registry",
      "dijit/form/Button",
      "dijit/layout/ContentPane",
      "dijit/layout/BorderContainer",
      "dijit/form/TextBox"
    ], function (
      FeatureLayer, FeatureTable, Extent, SimpleMarkerSymbol, SimpleLineSymbol, Color, Map,
      graphicsUtils, Query,
      domConstruct, dom, dojoNum, parser, ready, on,lang,
      registry, Button, ContentPane, BorderContainer, TextBox
      parser.parse();
      ready(function(){
        var map = new Map("map",{
          basemap: "dark-gray-vector"
        map.on("load", loadTable);
        function loadTable(){
            mode: FeatureLayer.MODE_ONDEMAND,
            outFields: ["*"],
            visible: true,
          // set a selection symbol for the featurelayer
          var selectionSymbol =  new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 12,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 255, 197, 1])));
          myFeatureLayer.setSelectionSymbol(selectionSymbol);
          map.addLayer(myFeatureLayer);
          // create new FeatureTable and set its properties
          var myFeatureTable = new FeatureTable({
            featureLayer : myFeatureLayer,
            map : map,
            showAttachments: true,
            // only allows selection from the table to the map
           // syncSelection: true,
           // zoomToSelection: true,
            gridOptions: {
              allowSelectAll: true,
              allowTextSelection: true,
            editable: true,
            dateOptions: {
              // set date options at the feature table level
              // all date fields will adhere this
              datePattern: "MMMM d, y"
            // define order of available fields. If the fields are not listed in 'outFields'
            // then they will not be available when the table starts.
            outFields: ["Address", "Created_Date", "Use_Type", 'OBJECTID'],
            // use fieldInfos property to change field's label (column header),
            // the editability of the field, and to format how field values are displayed
            fieldInfos: [
                alias: 'Building Size',
                editable: false,
                format: {
                  template: "${value} sqft"
                alias: 'Available Size',
                format: {
                format: {
                  template: "${value} parking"
                alias: ' ',
                editable: false,
                format: {
                  template: '<span class="esri-icon-zoom-in-magnifying-glass"></span>'
          }, 'myTableNode');
          myFeatureTable.on("load", function(evt){
          myFeatureTable.grid.on("td.field-OBJECTID:click", function(evt){
            var OID = myFeatureTable.selectedRows[0].OBJECTID;
            console.log(OID);
            zoomToSelected(OID);
            //Do your zoom event stuff here
          myFeatureTable.startup();
          // listen to show-attachments event
          myFeatureTable.on("show-attachments", function(evt){
            console.log("show-attachments event - ", evt);
          function zoomToSelected(Id){
            var query = new Query();
            query.returnGeometry = true;
            query.outFields = [ "*" ];
            query.where = "OBJECTID = '" + Id + "'" ;
            myFeatureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(features){
                  var extent = graphicsUtils.graphicsExtent(features).expand(1.25);
                  map.setExtent(extent);
  </script>
</head>
<body class="claro esri">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center', splitter:true" style="height:50%">
      <div id="map"></div>
    </div>
    <div id="bot" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom', splitter:true" style="height:50%">
      <div id="myTableNode"></div>
    </div>
  </div>
</body>
</html>
Tags (1)
ImtiyazPasha
Just checking no solution for 4.x FeatureTable widget?
