Hello, I have a map and using API key to display map. In API key I have disabled the basemap and using only feature layers without showing any map in the background. But if I do this map default zoom setting not working. Here is what I am trying:
<script>
require([
"esri/config",
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"esri/layers/support/LabelClass"
], (esriConfig, Map, MapView, FeatureLayer, LabelClass) => {
esriConfig.apiKey= API_KEY;
const map = new Map();
const view = new MapView({
map: map,
center: [85.7780685, 25.8560264],
zoom: 12,
container: "viewDiv",
constraints: {
snapToZoom: false
// Add district layer to the mapview
const districtLayer = new FeatureLayer({
url: "https://gis.fmiscwrdbihar.gov.in/arcgis/rest/services/GisAtlas/GIS_Atlas_2023/MapServer/22",
outFields:["*"],
map.add(districtLayer, 0);
</script>
In this, whatever value I set for the zoom it is not reflecting.
Solved! Go to Solution.
Hi @aggarwalarpit93, without a basemap I think you likely need to use the scale property instead of zoom.
require([
"esri/config",
"esri/Map",
esriConfig.apiKey = "";
map: map,
scale: 3000000,
constraints: {
snapToZoom: false
url:
outFields: ["*"]
require([
"esri/config",
"esri/Map",
map: map,
scale: 3000000,
constraints: {
snapToZoom: false
url:
outFields: ["*"]
Thank you so much for the help.
Please see screen dump attached: your data in an application without a basemap.
I slightly modified your code (see below) and, next to the districts I also added the settlements, which will become visible when you zoom in.
Yeah, zooming in and zooming out is working fine.
And yeah, @Sage_Wall is right: you should use the scale instead of the zoom property.
HTH,
Egge-Jan
<html>
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no" />
<title>Test: no background map</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.25/esri/themes/light/main.css">
<script src="https://js.arcgis.com/4.25/"></script>
<style>
html, body {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
font-family: sans-serif;
#header {
width: 100%;
height: 70px;
background-color: #154273;
color:#FFFFFF;
margin: 0;
#headertext {
float: left;
font-size: 35px;
color: white;
line-height: 70px;
padding-left: 15px;
#viewDiv {
position: absolute;
top: 70px;
bottom: 0;
right: 0;
left: 0;
padding: 0;
margin: 0;
</style>
<script>
require([
"esri/Map",
"esri/widgets/LayerList",
"esri/widgets/Expand",
], (Map, MapView, FeatureLayer, LayerList, Expand) => {
const settlementLayer = new FeatureLayer({
url: "https://gis.fmiscwrdbihar.gov.in/arcgis/rest/services/GisAtlas/GIS_Atlas_2023/MapServer/4",
minScale: 100000
map.addMany([districtLayer, settlementLayer]);
map: map,
scale: 1800000,
const layerList = new LayerList({
view: view,
listItemCreatedFunction: function(event){
const item = event.item;
item.actionsSections = [
title: item.layer.title,
className: "esri-icon-description",
layerList.on("trigger-action", function(event) {
if (event.action.id === "information") {
// If the information action is triggered, then open the item details page of the service layer.
window.open(event.item.layer.url);
const layerListExpand = new Expand({
expandIconClass: "esri-icon-layers",
// expandTooltip: layerList.label,
expandTooltip: "LayerList",
view: view,
expanded: true,
content: layerList,
group: "expandable-widgets"
view.ui.add([layerListExpand], "top-right")
</script>
</head>
<body>
<div id="header">
<div id="headertext" class="stretch">Test: no background map</div>
</div>
<div id="viewDiv"></div>
</body>
</html>
Thank you so much. Scale property is what I was looking for.
