Will showAttachments work if the rest endpoint is a map service?
2779
08-22-2014 01:13 PM
KenCarrier
I have been trying to get attachments to work against a map service and I am having no luck.
In Flex this was really easy but in JS it is proving difficult.
Based on how the documentation reads it appears JS only support viewing attachments on FeatureLayers and not MapServer services?
Format Popup Content | Guide | ArcGIS API for JavaScript
I am not sure why this would be the case as the map service I am working with shows at the REST endpoint show
Has Attachments: true
So why would JS not support attachments with a map service, is this really true? How are they getting around this in AGOL then?
RobertScheitlin__GISP
Ken,
  Yes you can do it here is a sample:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the
    samples on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>
      San Francisco
    </title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
    <style>
      html, body {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      .esriScalebar {
        padding: 20px 20px;
      #map {
        padding: 0;
    </style>
    <script src="http://js.arcgis.com/3.10/"></script>
    <script>
      var map;
      require([
        "esri/config",
        "esri/map",
        "esri/dijit/Popup",
        "esri/dijit/PopupTemplate",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/tasks/GeometryService",
        "dojo/dom-construct",
        "dojo/parser",
        "esri/Color",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dojo/domReady!"
        function (
          esriConfig, Map, Popup, PopupTemplate, ArcGISDynamicMapServiceLayer,
          SimpleMarkerSymbol, GeometryService, domConstruct, parser, Color
          parser.parse();
          esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
          var popupOptions = {
            markerSymbol: new SimpleMarkerSymbol("circle", 32, null,
              new Color([0, 0, 0, 0.25])),
            marginLeft: "20",
            marginTop: "20"
          //create a popup to replace the map's info window
          var popup = new Popup(popupOptions, domConstruct.create("div"));
          map = new Map("map", {
            basemap: "topo",
            center: [-122.448, 37.788],
            zoom: 17,
            infoWindow: popup
          var popupTemplate = new PopupTemplate({
            title: "{address}",
            fieldInfos: [
                fieldName: "req_type",
                visible: true,
                label: "Type"
                fieldName: "req_date",
                visible: true,
                label: "Date",
                format: {
                  dateFormat: 'shortDateShortTime'
            showAttachments: true
          var demographicsLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/MapServer");
          demographicsLayer.setInfoTemplates({
            0: { infoTemplate: popupTemplate }
          demographicsLayer.setVisibleLayers([0]);
          var layerDefinitions = [];
          layerDefinitions[0] = "address != ''";
          demographicsLayer.setLayerDefinitions(layerDefinitions);
          map.addLayer(demographicsLayer);
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'"
        style="width: 100%; height: 100%; margin: 0;">
      <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"
          style="border:1px solid #000;padding:0;">
      </div>
    </div>
  </body>
</html>
Ken,
<!DOCTYPE html>
<html>
  <head>
    <title>
      San Francisco
    </title>
    <style>
      html, body {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      .esriScalebar {
        padding: 20px 20px;
      #map {
        padding: 0;
    </style>
    <script>
      var map;
      require([
        "esri/config",
        "esri/map",
        "esri/dijit/Popup",
        "dojo/parser",
        "esri/Color",
        "dojo/domReady!"
        function (
          parser.parse();
            marginLeft: "20",
            marginTop: "20"
            basemap: "topo",
            zoom: 17,
            infoWindow: popup
            title: "{address}",
            fieldInfos: [
                visible: true,
                label: "Type"
                visible: true,
                label: "Date",
                format: {
    </script>
  </head>
      </div>
    </div>
  </body>
</html>
KenCarrier
Robert once again you are correct, in talking with Esri support they said it was not possible, looking over the ArcGIS JavaScript API documentation it leads one to believe this can only be done for feature service and not dynamic services. I am working with a template and I think this might be an opportunity to tweak the code to make it work for dynamic services. I am curious if you plan on developing anything like a template or if you plan on building widgets for WAB when it is released.
Here is the final product I was able to come up with.
!DOCTYPE html>
html>
head>
<title>
</title>
<style>
html, body {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
.esriScalebar {
padding: 20px 20px;
#map {
padding: 0;
</style>
<script>
var map;
"esri/config",
"esri/map",
"esri/dijit/Popup",
"dojo/parser",
"esri/Color",
"dojo/domReady!"
function (
"20",
"20"
new Map("map", {
"topo",
"TEST",
"STR_NAME",
true,
"Type"
"HyperLink",
true,
"Hyperlink"
true
var demographicsLayer = new ArcGISDynamicMapServiceLayer("http://engineer05.gomvo.org/arcgis/rest/services/SP/RoadRecords/MapServer");
</script>
head>
body class="claro">
</div>
</div>
body>
html>
Ken,
   I have already begun developing widgets for WAB.
KenCarrier
Awesome looking forward to seeing what you come up with.
StevenGraf1
Is this something they added in version 3.10?  I have been trying to accomplish this in earlier versions with no success.
