view.hitTest returning 0 results
11344
23
01-25-2017 10:30 AM
JasonRainwater
Hi, I am adding am empty feature layer on the fly in the browser.  After the fact I will add graphics to the source collection of the feature layer and my graphics all render correctly.
I setup the mapView.on("click") and I properly get the event with the click data.  I do the hit test then look at the results.
I am physically clicking directly on the rendered graphic but no matter what the hittest shows 0 results.
I have no idea where to start looking to see what I am doing wrong.  Any ideas?
VincentJones
Have you tried with version 4.12? This works for me. I want to use version 4.15 though so I am still looking for a solution...
GeoMarvelDeveloper
I haven't tried 4.12. I eventually abandoned the FeatureLayer client-side rendering and moved on to doing the same with a GeoJSON layer, which worked perfectly for me.
VincentJones
I finally tracked down what the issue was here. In my case I was reading the objectId from a data attribute and although a numeric value, it's type must have been considered string by the API; parsing as integer fixed the issue.
Hope this helps someone.
KevinCheriyan
Awesome. I can't test it right now. But this is good to know for my next time working with this!
Application Developer, GeoMarvel
