valueExpressionTitle not working
2390
06-28-2021 12:20 PM
JayHill
I'm trying to add labels to both the uniqueValues and the visualVariable parts of my legend.  The valueExpressionTitle = "Title" property is not working for me.
Link to codepen
JayHill
Ken
Figured it out.
Had this up in the css.
.esri-legend__layer-caption {
display: none;
I got ride of that css and I have them showing up now with this code.
          legendOptions: {
                  title: "Commodity Type"
KenBuja
MVP Esteemed Contributor
A quick glance shows a problem with the agreement with your require modules and your function arguments. They get out of sequence after CalciteMapsArcGIS. I don't know if this affects the visualVariables, but you should fix this first.
JayHill
Thanks Ken
I believe I fixed it but no luck getting the valueExpressionTitle working.
KenBuja
Can you provide a shorter example that highlights just the problem?
JayHill
Should be shorter now. The valueExpressionTitle (line 837), as I understand it, should provide a title to the visual variable (size) in the legend correct?  Ultimately I'm trying to label the two different ways the umosRenderer (line 633) is displayed in the legend. One title for the colored uniqueValues and one title for the size.
JayHill
Ken
Figured it out.
display: none;
          legendOptions: {
