Upgrading the API 1.3 to 3.1 and getting store error
1197
12-10-2012 07:20 PM
SunilPalkar
Hello All,
I am upgrading this tool to 3.1 and getting an error . When I use API version to 2.8 its working fine.
I understand that store properties are changed in 3.X version..but I am confused that where to do the changes ??
Any help will be great..thanks in advance : )
JeffPace
Hello All,
I had the same error, it was tricking to find.
its not the api thats the problem, its the dojo upgrade that comes with it
you can no longer do
item.store = mystore;
you now have to do
item.set ("store", mystore);
JeffPace
Hello All,
you now have to do
SunilPalkar
@ jeff
Thanks for your reply..I will check this and let you know.. thanks once again : )
