Here is the code that we have with our address locator. What do we need to do to get it to work?
<!DOCTYPE html>
<html>
<head>
<title></title> <!-- Define the versions of IE that will be used to render the page. See Microsoft documentation for details. Optional. -->
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta charset="utf-8">
<!-- Responsive -->
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=no">
<meta name="mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-status-bar-style" content="default">
<!-- End Responsive -->
<!-- Use protocol relative urls that way if the browser is viewing the page via HTTPS the js/css file will be requested using the HTTPS protocol -->
<link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.10/js/esri/css/calcite/calcite.css">
<link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.10/js/esri/css/esri.css">
<!-- Load any application specific styles -->
<link rel="stylesheet" href="css/styles.css">
<!--[if IE 8]>
<link rel="stylesheet" href="css/ie.css">
<![endif]-->
</head>
<body class="calcite app-loading no-touch">
<!-- Loading Indicator -->
<div class="loading-indicator">
<div class="loading-message" id="loading_message"></div>
</div>
<!-- Map -->
<!-- The ArcGIS API for JavaScript provides bidirectional support. When viewing the application in an right to left (rtl) language like Hebrew and Arabic the map needs to remain in left-to-right (ltr) mode. Specify this by setting the dir attribute on the div to ltr. -->
<div id="mapDiv" dir="ltr"></div>
<!-- Panel Content -->
<div id="panelContent">
<div id="panelPages"></div>
</div>
<!-- Panel Top -->
<div id="panelTop" class="bg rounded shadow">
<!-- Panel Title -->
<div id="panelTitle">
<div class="fc" id="panelText">
</div>
<div id="panelSearch">
<div id="panelGeocoder"></div>
</div>
<div id="panelMenu" class="icon-menu icon-color"></div>
</div>
<!-- Panel Tools -->
<div id="panelTools">
<!--Tools are created programatically-->
</div>
</div>
<script type="text/javascript">
var package_path = window.location.pathname.substring(0, window.location.pathname.lastIndexOf('/'));
var dojoConfig = {
// The locationPath logic below may look confusing but all its doing is
// enabling us to load the api from a CDN and load local modules from the correct location.
packages : [{
</script>
<script type="text/javascript" src="//js.arcgis.com/3.10/"></script>
require(["application/template", "application/main"], function(Template, Main) {
// create the template. This will take care of all the logic required for template applications
var myTemplate = new Template();
var myApp = new Main();
myTemplate.startup().then(function(config) {
myApp.startup(config);
}, function(error) {
// something went wrong. Let's report it.
myApp.reportError(error);
</script>
var map;
var locatorUrl = "http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer";
var myGeocoders = [{
url: locatorUrl,
singleLineFieldName: "SingleLine",
geocoder = new Geocoder({
map: map,
autoComplete: true,
arcgisGeocoder: false,
geocoders: myGeocoders
},"search");
geocoder.startup();
</script>
</body>
</html>
