Tip of the day - how to view the contents of an *.MSD file
7839
05-31-2011 04:33 PM
StephenLead
Honored Contributor
I just learnt this incredibly useful trick: if you rename an *.MSD file to be *.zip, you can open it up in WinZip and see the component *.XML files.
This allowed me to debug a complicated problem involving incorrect data paths - hard to do in the dark, but simple once I knew where to look.
ESRI - could we have an official viewer which allows us to do this legitimately?
MichaelMannion
Thank you for posting this! I know it's been a few years, but this same solution helped me yesterday with determining data sources for a map service in 10.5.1.
I struggle with this all the time in ArcGIS Server; I can't believe there's no other "likes" or replies to this thread yet. Simply knowing the original MXD path, as reported by ArcGIS Server Manager, doesn't conclusively answer the question about where a service is fetching its data. Often the original MXD is missing, or has been edited > re-saved in the interim.
Likewise, downloading the copy of the MXD that's stored on the server (.../arcgisserver/directories/arcgissystem/arcgisinput/<service>/extracted/v101/<service>.mxd) doesn't definitively identify a service's data sources, either. That document can point at local data sources from the publisher's machine that were subsequently uploaded to the managed geodatabase. Or, it can point at non-existent / incorrect files depending on whether the map was saved with relative or absolute paths.
Even setting the ArcGIS Server logging level to Debug and restarting services doesn't seem to report their source data locations. The only way I've found to determine a service's source data, for sure, is your MSD > ZIP rename trick. This information is so, so important, I have to assume that there's a better way of getting it, and that I'm just not aware.
  • Can anyone recommend a better method than the above for determining the data sources for layers in a map service?
In the meantime, thanks again Stephen for your valuable post.
DavidMather
Very Helpful Stephen!   Thanks!
TracyGarrison1
Great!  This was exactly what I needed.  logging in to Admin on portal host server using Admin would only tell me the msd path.   Using Manager I can see the original project file path but sometimes that project file is not available.   This method gave me the SQL Server name, the database name and username used to create the service.
