SVG symbol (or similar) in labels using Arcade
2600
03-21-2023 07:38 PM
julian_svcs
I have both positive and negative numbers and I would like to label my feature layer using either an up or down arrow. I am able to add this in the popup (see screenshot below) with an svg image, but this does not port over to the Arcade expression for labels.
Any idea if this is possible with labels?
Code snippet used for the popup:
const upArrow = '<svg width="16" height="16" ><polygon points="14.14 7.07 7.07 0 0 7.07 4.07 7.07 4.07 16 10.07 16 10.07 7.07 14.14 7.07" /></svg>';
const downArrow = '<svg width="16" height="16"><polygon points="0 8.93 7.07 16 14.14 8.93 10.07 8.93 10.07 0 4.07 0 4.07 8.93 0 8.93" /></svg>';
const diff =
      Math.round(feature.graphic.attributes[comparison_year_field]) -
      Math.round(feature.graphic.attributes[reference_year_field]);
const arrow = diff > 0 ? upArrow : downArrow;
Tags (4)
Sage_Wall
The Esri icon font can be used in labels.  You might need to create two label classes, one for the arrow icons and a second label class for the text or numbers using a standard font.
https://developers.arcgis.com/javascript/latest/esri-icon-font/#using-the-esri-icon-fonts-as-a-label
const skyConditionsExpression = `
  IIf(Find( 'Clear', $feature.SKY_CONDTN ) >= 0, '\ue64e', '\ue679');
const clearSkyConditionLabelClass = {
  labelExpressionInfo: {
    expression: skyConditionsExpression,
  labelPlacement: "above-left",
  minScale: referenceScale,
  symbol: {
    type: "text",
    color: "yellow",
    font: {
      family: "CalciteWebCoreIcons",
    haloColor: "gray",
    haloSize: 1.5,
  where: `SKY_CONDTN LIKE '%Clear%'`,
const cloudySkyConditionLabelClass = {
  symbol: {
    type: "text",
    color: "gray",
    font: {
    haloColor: "white",
    haloSize: 1.5,
  where: `SKY_CONDTN NOT LIKE '%Clear%'`,
julian_svcs
Thanks for the reply @Sage_Wall. I created two separate label classes as suggested and I am able to have the up/down arrow and the text but they do not align correctly. I think I created it correctly as you suggested. Below is an examle of the output and my code snippet used.
Code:
const nameArcadeArrows = `
    var diff = $feature.voltr_2028 - $feature.voltr_2016;
    var arrow = '';
    IIf(diff > 0, '\ue609', '\ue608');
const nameArcadeText = `
    IIf(diff > 0, diff, diff*-1);
const nameClassArrow = {
    expression: nameArcadeArrows
  symbol: {
    type: "text",
    color: "yellow",
    font: {
    haloColor: "gray",
    haloSize: 1.5,
const nameClassText = {
    expression: nameArcadeText
  symbol: {
    type: "text",
    color: "yellow",
    font: {
      family: "Arial",
    haloColor: "gray",
    haloSize: 1.5,
const featurelayer_line = new FeatureLayer({
  url: "https://[domain]/arcgis/rest/services/[service]/MapServer/5",
  title: "Difference between " + reference_year + " and " + comparison_year,
  renderer: linkRenderer,
  labelingInfo: [nameClassArrow, nameClassText],
  outFields: ["voltr_" + reference_year, "voltr_" + comparison_year],
  popupTemplate: popupTemplate,
  visible: true
Thanks once again.
Sage_Wall
Dang, in my head I had envisioned point features where you could set the labelPlacement property to different values for the two classes.  With polyline feature layers it looks like there isn't as much control over the position of the labels, the only labelPlacement option available for 2D polylines is `center-along`.
