SketchViewModel: disable deleting
1091
12-13-2024 01:33 AM
FernandaBarth_EsriPT
Hello,
I need to configure SketchViewModel to not allow deleting graphics but after a while searching it doesn't seem the sdk has this option, is there any way to disable deleting graphics? The 'delete' event also does not have the option to stopPropagation.
The only work around I imagined is to do graphicsLayer.graphics.addMany(event.graphics) at the delete event, but not the best solution I think.
JoelBennett
MVP Regular Contributor
An alternate way would be to override the delete function:
sketchViewModel.delete = function() { };
The above would cause nothing to happen when the delete function is called.  If you needed to remove any graphics created by that module, you'd have to use some alternate means, like:
sketchViewModel.layer.removeAll();
JoelBennett
Thank you  @JoelBennett. Didn't think about this option and works well.
