SketchViewModel.activeLineSymbol
1317
07-14-2021 01:14 PM
EthanBodin1
The API documentation for SketchViewModel in v4.20 includes an activeFillSymbol property though it does not include the activeLineSymbol property that is present on SketchViewModel objects in the debugger. Is activeLineSymbol not intended to be used?
JoseBanuelos
Hello @EthanBodin1
We purposely did not publicly document the activeLineSymbol property. There was demand to document the activeFillSymbol but not for the activeLineSymbol. I believe, as you may feel as well, it would make more sense to publicly document this. We will strongly consider this for next release. There were some concerns initially on exposing this, but we will be looking into this again. Appreciate your feedback. You can use the activeLineSymbol in the meantime, there is just no documentation on this at the moment.
Jose
JoseBanuelos
Hello @EthanBodin1
Jose
EthanBodin1
Thank you for the response @JoseBanuelos. I will use activeLineSymbol and hope to see it documented in a future release.
