Show attachments in InfoTemplate for jQuery Mobile
3768
03-31-2015 06:54 AM
RobertKirkwood
How do you get the attachments to show in the InfoWindow for this example? I can see them when you create a point, but when you identify the point it is not there.
https://developers.arcgis.com/javascript/jssamples/mobile_citizenrequest.html
If the code is modified on line 693 to  "showAttachments": true, then the window when collecting a point looks like this:
I would like the Attachments to show up in the identify window as well.
The template is being created by this code:
var featureLayerInfoTemplate = new InfoTemplate();
                        featureLayerInfoTemplate.setTitle("<b>Secies Type: ${SpeciesType:speciesDomainLookup}</b>");
                        var infoTemplateContent =
                                "<span class=\"infoTemplateContentRowLabel\">Date: </span><span class=\"infoTemplateContentRowItem\">${sampDate:DateFormat}</span><br>" +
                                "<span class=\"infoTemplateContentRowLabel\">Species Type: </span><span class=\"infoTemplateContentRowItem\">${SpeciesType:speciesDomainLookup}</span><br>" +
                                "<span class=\"infoTemplateContentRowLabel\">Common Name: </span><span class=\"infoTemplateContentRowItem\">${commonName:commonNameDomainLookup}</span><br>" +
                                "<span class=\"infoTemplateContentRowLabel\">Phenology: </span><span class=\"infoTemplateContentRowItem\">${plantPhenology:phenologyDomainLookup}</span><br>" +\
                                "<span class=\"infoTemplateContentRowLabel\">Habitat: </span><span class=\"infoTemplateContentRowItem\">${Habitat:habitatDomainLookup}</span><br>" +
                                "<span class=\"infoTemplateContentRowLabel\">Weather: </span><span class=\"infoTemplateContentRowItem\">${Weather:weatherTypeDomainLookup}</span><br>" +
                                "<span class=\"infoTemplateContentRowLabel\">Is Sensitive?: </span><span class=\"infoTemplateContentRowItem\">${IsSensitive:sensitiveTypeDomainLookup}</span>";
                        featureLayerInfoTemplate.setContent(infoTemplateContent);
That code does not specify whether or not attachments are visible. I want to be able to see the attachment manager in that window.
YousefQuran
You can find it simply by clicking the right arrow on the InfoWindow which is located on most right of the InfoWindow.
-Yusuf
Amman, Jordan.
RobertKirkwood
The attachments do not show up in that info window. The template is being created by this code:
