Set hyperlink in InfoTemplate by field in attribute table
4307
08-12-2015 11:39 AM
AshleyPeters
I have a field in my attribute table that contains a link to a web page. In Flex, I was able to create a hyperlink using this field to populate the appropriate place in my popup. I'd like to do the same now with JavaScript.
I have the InfoTemplate set up and it looks perfect. However, when I click on the link, a new browser page is opened, but it does not go to the link contained in my attribute table. Instead, it is opening a new page of the project I'm working on. How do I need to rewrite the href section of this code for the link to work?
Thanks in advance for your help!
Here's my code:
var stateParksInfoTemplate = new InfoTemplate();
stateParksInfoTemplate.setTitle("<b>${NAME}</b>");
var stateParksInfoContent =
"<div class=\"InfoContent\">" +
"For more information on <b>${NAME}</b>, please <a href='${LINK}' target='_blank'><font color='0x84CCDA'>click here</font></a>."
+ "</div>";
stateParksInfoTemplate.setContent(stateParksInfoContent);
ChrisSmith7
Honored Contributor
Ashley,
This came-up a few times in the past - it seems to be a common question! I had issues with links myself before... Have a look at the following threads - they may have some info to help you:
additional function in infotemplate hyperlink
InfoWindow fields - URLs automatically add "_blank" as target
AshleyPeters
Thanks Chris,
I've got it working now. I had a capitalization issue, LINK should have been Link.
Ashley
ChrisSmith7
Honored Contributor
Cool - easy fix!
