Search Widget Expand not functioning properly in Boostrap 5 Navbar.
703
04-03-2023 09:05 AM
LeonDavis
Hi  there,
I'm trying to use the Expand Widget containing a search widget, within a custom Bootstrap 5 navbar. however it isn't expanding to the left properly. It works fine within the mapview (where its intended to work I guess...)
I've made a simple codepen to demonstrate the issue. https://codepen.io/10ldavis/pen/mdGNLJm
any tips would help a lot.
Thanks so much for the help guys, it's really appreciated 🙂
JamesIng
If you add a `z-index` onto your #searchDiv it'll ensure it's not hidden underneath the map element.
You'll still likely want to add some additional CSS styling to just tweak the expanded position slightly.
James from www.landkind.com
