Run Directions widget from my own Points
2181
11-04-2021 04:36 AM
benchikh
I'm working with Directions widget under arcgis api js 3.38, and I want to start and run my directions from some points (lat, long) coming from my database.
so I need to pass the points to the directions widget and get the points rendered with route on the map.
Could you please help me with a sample or a code details that would be much appreciated.
Many thanks
Noah-Sager
Hi @benchikh, offhand, I don't think we have a sample that does this, but you could use the locationToAddress method on the Locator class to generate an address from each of the point.
https://developers.arcgis.com/javascript/3/jsapi/locator-amd.html#locationtoaddress
And then pass these to the Directions widget using the addStops method.
https://developers.arcgis.com/javascript/3/jsapi/directions-amd.html#addstops
Hope this helps!
benchikh
Hi Many thanks for your feedback.
I did the below work, but I get just lat and lon coordinates on the source and destination inputs and did not got a label of the points " Looks like the locator did not work correctly!"
var adr = locator.addressesToLocations(new Point(-760817.9, 4031811, new SpatialReference({ wkid: 102100 })));
directionsW.addStop((adr, 100), 1);
could you please help ?
Noah-Sager
You should try the locationToAddress() method, not the addressesToLocations() method like in your code snippet above.
benchikh
Hi Many thanks, Will try it
