Return more than one result with hitTest
3180
11-04-2018 09:58 AM
MichaelLodes2
view.on("click", function (event) {
  event.stopPropagation();
  var htr; // a single result from HitTestResult results[]
  view.hitTest(event)
     .then(function (response) {
       if (response.results.length){
         htr = response.results.filter(function (result) {
          return result.graphic.layer === lyr;
         })[0];
         console.log(htr);
         if (htr !== undefined){
             var arr = [];
             arr.push(htr.graphic);
             view.popup.open({
                 features: arr
I'm using the above hitTest function to check wether the user clicked on a feature that is overlapped by a query result feature and open its popup. It is working fine but when clicking on two or more features at the same time i want the arrow to appear in the popup, so the user can switch through. Is it possible to return more than one result?
RobertScheitlin__GISP
Michael,
   No the hit test will return one graphic. If you need to get the overlapping graphics you have to do a query using the click point as the queries geometry.
Michael,
TVlasschaert
I have such a query working client-side for any given FeatureLayerView, but how to do the same for a GraphicsLayerView?  GraphicsLayerView supports a queryGraphics() method, but this simply returns all records and there is no way to do a client-side filter that leverages a spatial index (geographically comparing all graphics would be too slow).
The MapView.hitTest doc indicates, "At 4.22 and later, a hit test will return *all* graphics from GraphicsLayer that intersect the specified coordinates.".   I'm using version 4.22.2 and in my testing it is only returning a single graphic from the GraphicsLayer, and I don't see any option to affect this.  IMO the doc seems to be misleading?
I need to use a GraphicsLayer because I want to create a unique CIMSymbol for each feature depending on multiple attributes / complex logic.
