I have polygons with multiple rings. At some zoom level I am rendering polygons to points, but only one point is rendered to multi polygons.
Is it possible to render points for each ring?
Do you want to render the vertices of the polygon to points? Or the center of the polygons to points?
You would need to break the polygon into polylines and the polylines into points. I have a utility you can use for that.https://github.com/odoe/explode/
For the render to polygon to points, you can define the renderer to display points and it will use the centroid of the polygon.
https://developers.arcgis.com/javascript/latest/api-reference/esri-renderers-SimpleRenderer.html
The center can be a little off if it's an oddly shaped polygon, like a horse shoe or something.
I have objects with multiple drawn polygons to them. I am using a feature service. These polygons are all around the city.
If I change the renderer to simple-marker it only renders one polygon to point and that's it.
That's expected. So you want to show the vertices of the polygon as points? You'll need to break it down to points using something like the explode utility I linked above. Polygons -> Polylines -> Points
