I have several layers getting loaded according to the user's rights towards them. Forexample. I have rights to access only to 5 layers out of 10, I will be viewing only 5 layers in my map and not all the layers. So, I dynamically generate it. Now, for search option to be present for every layer, The sources for the search was given from the ajax call. The layers are getting listed in the dropdown perfectly, but when I search in a particular layer or in "ALL" category it is throwing the following error:
init.js:199 Error: Target must be an event emitter(…) "Error: Target must be an event emitter
<SPAN class="keyword token">var</SPAN> searchParams <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
$<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ajax</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"POST"</SPAN><SPAN class="punctuation token">,</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"WebService.asmx/featurelist"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="comment token">//getting the allotted feature lists for this particular user</SPAN>
data<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"{ 'aData': '"</SPAN> <SPAN class="operator token">+</SPAN> userid <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'}"</SPAN><SPAN class="punctuation token">,</SPAN>
contentType<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"application/json; charset=utf-8"</SPAN><SPAN class="punctuation token">,</SPAN>
dataType<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"json"</SPAN><SPAN class="punctuation token">,</SPAN>
success<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>data<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> myData <SPAN class="operator token">=</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN>data<SPAN class="punctuation token">.</SPAN>d<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// console.log(myData);</SPAN>
<SPAN class="keyword token">var</SPAN> url1 <SPAN class="operator token">=</SPAN> serviceLoc<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> url2 <SPAN class="operator token">=</SPAN> <SPAN class="string token">"/MapServer/0"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> myData<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
searchParams<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
featureLayer<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="operator token">+</SPAN> finalurl <SPAN class="operator token">+</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN> <SPAN class="operator token">+</SPAN> myData<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>Fname <SPAN class="operator token">+</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> search <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Search</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
sources<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoomScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">5000000</SPAN><SPAN class="punctuation token">,</SPAN>
placeholder <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">" Object id / Facility No "</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"shoo"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
search<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> sources <SPAN class="operator token">=</SPAN> search<SPAN class="punctuation token">.</SPAN>sources<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// console.log(JSON.stringify(searchParams));</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> searchParams<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
sources<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
featureLayer<SPAN class="punctuation token">:</SPAN> searchParams<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>featureLayer<SPAN class="punctuation token">,</SPAN>
name<SPAN class="punctuation token">:</SPAN> searchParams<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">,</SPAN>
placeholder<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Object ID"</SPAN><SPAN class="punctuation token">,</SPAN>
enableLabel<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
searchFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
displayField<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
supportsPagination<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
enableSuggestions<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
enableSuggestionsMenu<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
suggestionTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Object ID: ${OBJECTID}"</SPAN><SPAN class="punctuation token">,</SPAN>
exactMatch<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
maxResults<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN>
maxSuggestions<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN>
infoTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">InfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Object ID - ${OBJECTID}"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Ipsum Doler"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="comment token">//Set the sources above to the search widget</SPAN>
search<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"sources"</SPAN><SPAN class="punctuation token">,</SPAN> sources<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
search<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>If I hard code every layer on the sources array, it is working fine, but it is not working fine if I load it dynamically. I am clueless now, I request any of you give some solutions for it.
Thanks in advance
