I upgraded to 4.18 and suddenly it failed when querying the data against GeoJSONLayer using mouse click event
This code used to work in 4.17
https://codepen.io/pegafal/pen/wvgebNd
Any idea how to fix this?
Hi there,I am able to reproduce the issue and thanks for reporting this issue. In meantime, at 4.18, you can use
Polygon.fromExtent method to workaround this issue.
I have updated your test app use this method and the results are returned as expected. I will update you once we have a fix for this issue.
Hope this helps,
Undral
Thank you. Worked perfectly
Hi there, I am letting you know that this issue will be fixed at version 4.28 and it is expected to be released end of October.
