How to use demographics data in ArcGIS JavaScript APIs to get the locations with the highest population in a pre-defined area.
i.e. I want to get the top 10 locations with the highest population inside New York City
Many Thanks.
When you say custom blocks - are you not using the blocks provided by the Census? You can easily get this info from them:
http://www2.census.gov/geo/tiger/TIGER_DP/2011ACS/2011_ACS_5YR_BG_36.gdb.zip
Here's the metdata:
http://www2.census.gov/geo/docs/maps-data/data/tiger/prejoined/ACSMetadata2011.txt
You would want to look at B01001e1, which is total population.
Thanks Chris.
My area is a custom Block layer (Polygon layer) and I need with somehow intersect this layer with demographic data then get the top 10 blocks from the population perspective.
I just want to get the names or IDs of the blocks without drawing them on map.
Well, that's a loaded question. What is your pre-defined area type? County? Zip? Census Block/Tract? Do you just need to know the fips codes/names for the top 10 areas and their population and/or do you need to see it on a map?
Signed in members can post, follow updates, and more. New here? Register a free account.
