I'm having problems publishing a mosaic raster that has a time dimension. I have ArcGIS Image Extension installed, and am able to publish an image service, but the result doesn't carry over the pixel values (every cell is valued at 1.134274E+38). I followed the steps from ArcGIS Help 10.1 . I didn't register the underlying data, instead transferring everything (12 rasters) to the server. Here are some screen shots that might explain more:
What I began with in an mxd (originalMosaicRasterMxdTimeDimension.png)
Some of the parameters I had in the Service Editor (ConvertingToImageService.png)
The result, when I drag the image service into an mxd, to view (ResultsNotCarryingOverValue.png).
Would appreciate any help, or if more information is needed for a meaningful answer, let me know - I wasn't sure what parameters to include.
David
