Print/Export without Interacting with Map
2287
09-07-2016 11:14 PM
HenryKo3
How can I generate a PNG/JPG image from an simple map without any user interaction?
On a particular page on our website, we have a small and simple JavaScript API 3.17 map embedded in the corner of the web page. It only contains an Esri basemap with a simple point graphic. This map is not interactive (i.e. users cannot zoom and pan etc) as its purpose is just to show the location of the point. Apart from the basemap
Now, on the same web page, users can click a button to generate a PDF file. This PDF file needs to have that map image included. This is illustrated in the image below:
How can I do this? The Print Task in JavaScript API needs to be called by interacting with the actual map. I am not sure if I can use a geoprocessing service to print from the JavaScript based map?
PanagiotisPapadopoulos
RobertScheitlin__GISP
Henry,
   Here i a snipitt of code I use just for that using the Export Web Map Task that Panagiotis suggests above:
        this.map.infoWindow.hide();
        var oWid = this.map.width;
        var oHgt = this.map.height;
        var printTask = new PrintTask('http://yourserver/arcgis/rest/services/ExportWebMap/GPServer/Export%20Web%20Map%20Task');
        var template = new PrintTemplate();
        //code for maintaining aspect ratio of the image, you will want to adjust numbers likely
        this.imgHeight = (740/oWid) * oHgt;
        template.exportOptions = {
          width: 1542,
          height: (1542/oWid) * oHgt,
          dpi: 200
        template.format = "jpg";
        template.layout = "MAP_ONLY";
        template.preserveScale = false;
        template.showAttribution = false;
        var params = new PrintParameters();
        params.map = this.map;
        params.template = template;
        printTask.execute(params, lang.hitch(this, this.printResult));
      printResult: function(rsltURL){
        var mapImg = domConstruct.toDom('<img src="'+rsltURL.url+'" border="0" style="width:740px;height:'+this.imgHeight+'px;"/>');
        domConstruct.place(mapImg, dom.byId('mapImgDiv'), 'replace');
