Hey
Is there a way to keep first popup open when click somewhere on map and open another popup?
Issue is like when I click somewhere on map, the previous popup got closed and new one got opened at that map point. But i want to keep that popup open and only it should close when user click close(X) button inside popup.
My requirement is to get coordinates and show it popup and keep the popup open even if another popup opens, similar to multiple popup. I'm using ArcGIS 4.10 version. Used the default popup as showed in ArcGis document, but unable to find the way to keep this popup open
