Plot path with spatial reference conversion
922
09-13-2020 10:22 AM
JasonWood
JS & ArcGIS newb here.
I have a working example (thanks to this forum) that translates from an alternate spatial reference and plots a point on a map. As you can see from the commented out lines below - I am trying to adapt this to plot a path, but I'm not having luck.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>Basic Map</title>
  <style>
    html, body, #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.15/esri/themes/light/main.css">
  <script src="https://js.arcgis.com/4.15/"></script>
  <script>
    //Style point
    var simpleMarkerSymbol = {
        type: "simple-marker",
        color: [226, 119, 40],  // orange
        outline: {
            color: [255, 255, 255], // white
            width: 1
    //style line
    var simpleLineSymbol = {
        type: "simple-line",
        width: 2
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/Graphic",
      "esri/layers/GraphicsLayer",
      "esri/geometry/Point",
      "esri/tasks/GeometryService",
      "esri/tasks/support/ProjectParameters",
      "esri/geometry/SpatialReference"
    ], function(Map, MapView, Graphic, GraphicsLayer, Point, GeometryService, ProjectParameters, SpatialReference)  {
        var sr = new SpatialReference({
            wkid: 2953
        var map = new Map({
            basemap: "topo-vector"
        var graphicsLayer = new GraphicsLayer();
        map.add(graphicsLayer);
        var point = Point({
            type: "point",
            x: 2637779.94,
            y: 7418399.63,
            spatialReference: sr
        var parcelOutline = {
            type: "polyline",
            paths: [[2637816.5,7418383.95],[2637788.4,7418370.9],[2637760.75,7418357.95],[2637743.65,7418416.45],[2637799.35,7418440.55],[2637816.5,7418383.95]],
        var geomSer = new GeometryService({url: 'https://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer'});
        var params = new ProjectParameters({
            //geometries: [point],
            geometries: [parcelOutline],
            outSpatialReference: new SpatialReference({wkid:102100})
        geomSer.project(params).then(function(results){
            //var pointGraphic = new Graphic({
            //   geometry: results[0],
            //    symbol: simpleMarkerSymbol
            var parcelOutlineGraphic = new Graphic({
                symbol: simpleLineSymbol
            var view = new MapView({
                container: "viewDiv",
                map: map,
                center: results[0],
                zoom: 13
            //graphicsLayer.add(pointGraphic);
            graphicsLayer.add(parcelOutlineGraphic);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
RobertScheitlin__GISP
Jason,
   Couple of issues.
  1. You are trying to give the geometry service an simple object and not an actual geometry class object.
  2. You are trying to set the views center to a line when it only takes points.
<!DOCTYPE html>
<html>
<head>
  <style>
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    //style line
        width: 2
    require([
      "esri/Map",
      "esri/Graphic",
      "esri/geometry/Polyline",
    ], function(Map, MapView, Graphic, GraphicsLayer, Polyline, GeometryService, ProjectParameters, SpatialReference)  {
            wkid: 2953
        var map = new Map({
        var parcelOutline = Polyline({
            type: "polyline",
                map: map,
                center: results[0].extent.center,
                zoom: 13
  </script>
</head>
<body>
</body>
</html>
