PictureMarkerSymbol not showing
4640
04-04-2019 10:34 AM
mingleidi
I upgraded from 4.5 to 4.11, now PictureMarkerSymbol is not showing on the map, it's a client-side feature map, I confirmed my IIS is  CORS enabled, and I even tried with esri image like this:
symbol
type: "picture-marker",
// url: this._getAQHIIcon(attributes.AQHI),
url:
"https://static.arcgis.com/images/Symbols/Shapes/BlackStarLargeB.png",
contentType: "image/png",
width: 24,
height:36
still not working,  I didn't set render for this feature layer, the image is selected from a list of icons based on an attribute value. Now it just shows dots. Could anyone please help out? This issue already took me days. Below is my code for feature layer:
featureLayer = new FeatureLayer({
fields: this.config.layerDefinition.fields,
objectIdField: this.config.layerDefinition.objectIdField,
geometryType: "point",
source: this._generateGraphics(this.config.view.zoom),
popupTemplate: ({
title: "{CommunityName}" + " - Air Quality Health Index",
content: "{AQHI:getCommunityAqhiPopupContent}"
} as any) as PopupTemplate
_generateGraphics(zoomLevel: number): Array<Graphic> {
let graphics = this.allCommunityAqhis.map((data: any, i: number) => {
if (data.Longitude && data.Latitude) {
return this._createCommunityAqhiGraphic(data, i, zoomLevel);
}) as Array<Graphic>;
return graphics;
_createCommunityAqhiGraphic(data: any, objectId: any, zoomLevel: number) {
let point, attributes, symbol;
point = WebMercatorUtils.geographicToWebMercator(
new Point({
x: data.Longitude,
y: data.Latitude
symbol = {
url:
width: this.config.iconWidth,
height: this.config.iconHeight
return new Graphic({
geometry: point,
symbol: symbol,
attributes: attributes
Attached screenshot. right side is working in 4.5, left side is not working in 4.11.
Benjamin
ReneRubalcava
Esri Frequent Contributor
ReneRubalcava
It looks like you are trying to add the symbol to the graphic. When using a FeatureLayer, the symbol needs to be defined on the renderer of the layer. https://developers.arcgis.com/javascript/latest/api-reference/esri-renderers-SimpleRenderer.html
It would look something like this.
const renderer = {
  type: "simple",
  symbol: {
    url: "https://static.arcgis.com/images/Symbols/Shapes/BlackStarLargeB.png",
  renderer: renderer, // Your renderer
  popupTemplate: ({
mingleidi
Hi Rene, thanks for your prompt reply. I cannot use Simple render because each graphic needs to use a different icon based on its attribute data, previous pasted code just for an example, below is actual code, it assigned a different icon to each graphics based their value dynamically:
symbol = this.config.is3D
? this._getPointSymbol3DObject(attributes.AQHI)
geometry: point,
symbol: symbol,
_getAQHIIcon(aqhiValue: any) {
// default icon for community
let icon = this.config.iconPath + "aqhi_blank.png";
// icon changes depending on the AQHI status
if (aqhiValue !== null && aqhiValue > 0 && aqhiValue <= 10) {
icon = this.config.iconPath + "aqhi" + aqhiValue + ".png";
} else if (aqhiValue > 10 || aqhiValue === "10+") {
icon = this.config.iconPath + "aqhi10plus.png";
return icon;
for exmaple. if graphic aqhi value is 1, it's assigned aqhi1.png.  It'w working fine is 4.5.  Is in 4.11 feature layer must have a render?
Benjamin
ReneRubalcava
Then you can use a Unique Value Renderer.
UniqueValueRenderer | ArcGIS API for JavaScript 4.11
mingleidi
Thanks Rene, I will try it, should be the solution.
